fargo_182 Posted March 19, 2007 Report Posted March 19, 2007 On the 3.4 you know where the collant hoses all meet on the pasenger side at the front. Well for starters the idiot who I bought it from put a thermostat in there and for a year now I couldnt for the life of me figure out why it was over heating, it was backwards too btw. Garages thought it was a head gasket and I kne wit wasn't. Anyways he stripped the hole the top piece goes into on this connector so I was just wondering is it removable or part of the block? I can't really see, just wondering if someone knew. If its replacable I can fix it if not I don't know what to do. Quote
jtmarten Posted March 20, 2007 Report Posted March 20, 2007 I'm not surprised someone put a stat in there. The housing looks like a stat housing. I'm pretty sure that housing bolts directly to the block. If the block is stripped you'll have to drill/tap for a larger bolt, and ream the bolt hole on the housing, or drill/tap and install a Helicoil thats the original size. Quote
