stockgp Posted March 19, 2007 Report Posted March 19, 2007 i don't know exactly how to explain it, but the sunroof in my 94 doesn't work. if i use the switch, i can hear the motor turn for less than a second and quit. if i take the motor out, it turns freely both directions. so, i can take the motor out of my 90 and use it. however, if the motor isn't the problem it does me no good. has anyone else experienced the sunroof binding up? any suggestions on fixing it? Quote
buckethead Posted March 20, 2007 Report Posted March 20, 2007 You should probably take the whole sunroof assembly apart and clean up and re-lube the tracks and moving parts. I would try that before replacing the motor. Quote
FordBoy Posted March 20, 2007 Report Posted March 20, 2007 If its been a long time sence its been opened it could have vapor lock ya just try to take it apart and clean it up that should fix the problem Quote
