Hey guys... I just finished swapping a 91' CS Digital UB3 into a 93' CS that had the Base cluster. I used the home pages walkthru, and got everything working correctly. I only had to run 1 wire for the tach. After I was done, the was 2 wires left that weren't used. 1 was the white wire that was for the base clusters tach, and the other was brown, I don't know its purpose.
My question is... The 91' that the UB3 came out of had standard HVAC controls, the 93' that I swapped it into has digital HVAC controls. I read somewhere that the e/m switch on the cluster can also make the digital HVAC change from english to metric. I see in the pinouts that pin D9 (LT BLU) E/M OUTPUT TO HVAC & DIS should be run to the HVAC unit....
Has anyone else done this yet? I know its a lame feature, but I wanna make it work if I can. Cmon CrazyK I know you must know what I'm talking about...
hmmm, i didnt know that the ecc changed, never cared I guess. I know that you can link the UB3 with the DIS, but I didn't know about that. The extra wires are for the security, and something else. I have two, but the other is for the airbag light, which since you have a 93, that wouldnt be there
Ok I have been working on getting the ECC to change to metric for the last 3 hrs...
I can see on the ECC screen that it is capable of displaying farenheit and celcius. I thought that since it is prewired for a hud, I could simply attach into the hud harness's e/m wire and the ECC would be linked... it wasn't. The ECC has 3 plugs, each with 7 wires. Each connector is a different color. Black, White, Gray. Out of the 3 plugs, there are 3 LT BLU wires. I'd hate to have to just start grounding out wires....
Could someone post a pinout for a 93' Cutlass Supreme electronic climate control?
WOOT!
I got it, all I had to do was run a wire from pin D9 at the instrument cluster to pin 11 in C2 (Black Connector) at the back off the ECC.
If anyone is interested here are the 89-93 CS ECC Pinouts...
C1:
7. LIGHT GREEN/BLACK – DEFROST solenoid control
8. TAN – A/C solenoid control
9. PURPLE – BI-LEV solenoid control
10. LIGHT BLUE – RECIRC solenoid control
11. LIGHT BLUE – Temp door motor control
12. PURPLE/YELLOW – radio for dimming of the display
13. GRAY – light switch for illumination
14. BLACK – ground
15. Not used
C2:
7. BROWN – Air temp door variable feed
8. Not used
9. DARK GREEN – Inside air temp sensor
10. LIGHT GREEN/BLACK – outside air temp sensor
11. Not used
12. LIGHT BLUE – rear defogger timer relay
13. LIGHT GREEN – A/C request (goes to ECM)
14. RED – HEATER Solenoid
15. GRAY/BLACK – to blower controller (C1-B)
C3: (Black Connector)
7. BLACK - Ground
8. ORANGE – to ELEC fuse (hot at all times)
9. ORANGE – To ALDL
10. DARK GREEN – to ALDL
11. BLACK – GROUND (this is for the E/M switch. If you ground it, then the display will be in *C, instead of *F. Either connect it to the E/M switch, or just straight ground it for canadian cars)
12. PINK/BLACK – CLUSTER fuse (hot in run)
13. YELLOW – Sensor Ground for inside, and outside Air Temp Sensors
14. PURPLE/WHITE – rear defogger ON indicator
15. PURPLE – to blower motor
