paulo57509 Posted March 17, 2007 Report Posted March 17, 2007 I need to replace the ignition switch in my '92 Lumina (the switch, not the key cylinder). If I do it by the book, I'll have to remve the steering column from the car. If anyone has done this before, I'd like to hear your stories. Is there enough room to access the switch if I just remove the steering wheel, unbolt the column from the dash and just let it hang down? TIA. Quote
White93z34 Posted March 17, 2007 Report Posted March 17, 2007 if i remember right the switch itself is on the top of the column back under the dash. so you would have to at least pull the column down to get at it. Quote
paulo57509 Posted March 17, 2007 Author Report Posted March 17, 2007 Thanks, Chris. I figured on just pulling the column down. If that doesn't yield enough room to get to the switch, I can always continue on and remove the column. Quote
Crazy K Posted March 17, 2007 Report Posted March 17, 2007 you can do it with the column down. take the fours bolts out that hold the column, but leave the shaft attached to the jopint at the bottom. Quote
