i changed my both axles about a year ago...heres the thing when im backing out (sometimes) i hear a clanking noise but only in reverse ...other than that its ok car doesnt feel shaky at high speeds, doesnt make the noise when i turn, cv boots arent ripped, i have new inner and outer tierods, any ideas?
Do you here clicking when you turn in any gear or any direction if so then its your CV shafts (axles)
lift the tire off the ground, if the wheel shakes all around, its a bad berring
it clicks while turning in reverse only thats it.... the ball joints are not to bad they dont seem like they need to be replaced but imma go ahead and do it ne way.... i guess ill try that wheel bearing trick see whats up
