water out of exhuast
i recently noticed that if i hit 3k rpm and back off while idle i get a back fire sound out of the exhuast , and if i try to go over 4 k it skips like holy hell and shoots water out of the exhuast .... hmmm bad gas??? not sure
I'm not sure if water coming out of the exaust is a problem, I notice alot of cars new and old that leak water from the exaust.
The back fire is not normal though it good be anything from bad gas, a sensor, or part of the ignition system.
thanks , i just went put some 93 octane in there this morning , hopfully that will help ... if not ill start to check those things out ... thanks alot bro :)
I do believe that water vapor actually a product of combustion, so at least that part of it is normal.
That's correct... cold exhaust pipes with warm water vapor condenses the vapor into a liquid.
Basic combustion fomula (unbalanced): [ CH4 + O2 ---> H2O + CO2 ]
Nothing to worry about! It's all basic chemistry.
- RedFox340
Probably not the gas
I use the ultra-premium always and my car still does the exact same thing your describing.
Tell me though. When youre car has been stopped at a light or idling for a while does the RPMs start to drop slightly in a rythmic pattern? My car also does that and i was wondering if yours does it too maybe its a connected problem
my car does that too.... I'm pretty sure it's my fuel injector, so you may want to check that out....
i'm hoping that isnt what mine is. i hope it is just a sensor or blocked cat
If he's gone though a least one tank of gas and still has the problem then your right, but somtimes there are bad batches. My moms spark plugs got messed up by bad gas.
i belive i have come to a conclusion ... rev limiter since it only does it while in park , drive it will go over 4 ... tanks for the help guys =)
And in neutral if under a certian speed.
- RedFox340
thx now i can stop being perinoid thinking my engine is messed , stupid rev limiter ... :wink:
