Here's one for you guys
1. Remove the right side fender
2. Jack up the car
3. Remove the engine
4. Adjust the rear monoleaf
5. Replace the U-bend with straight pipe
6. Take off the passenger side axle
7. Drain the oil
8. Remove power steering pump bolts
9. Remove oil pan
10. Change wiper blades
11. Cut the power steering lines
12. Install new power steering lines
13. Remove pump
Installation is reversed.
2. Jack up the car
7. Drain the oil
9. Remove oil pan
13. Remove pump
:lol:
2. Jack up the car
7. Drain the oil
9. Remove oil pan
13. Remove pump
:lol:
smart ass lol
No seriously the bolts holding it on wont come out far enough and there arent holes in the plulley like other cars to puill them through, WTF????
How about removing a PS pump from an L36? :lol: Mine whines like crazy and it's annoying.
/end hijack
1. Remove the power steering pulley from the power steering pump. Refer to Power Steering Pulley Replacement .
2. Remove the power steering pressure hose from the power steering pump. Refer to Power Steering Pressure Hose Replacement .
3. Remove the power steering return hose from the power steering pump. Refer to Power Steering Return Hose Replacement .
4. Remove the power steering pump mounting bolts.
5. Remove the power steering pump assembly.
6. Remove the power steering pump reservoir from the power steering pump.
2. Jack up the car
7. Drain the oil
9. Remove oil pan
13. Remove pump
:lol:
lolol wise ass
2. Jack up the car
7. Drain the oil
9. Remove oil pan
13. Remove pump
ahajajajaa
