TLOC Posted March 12, 2007 Report Posted March 12, 2007 I tore apart the TGP to do this fix, no problems but the drive pump will not come out. Large channel locks, vise grips, pulling hard upward, it just spins, I can turn it by hand, is this normal? Any help? Also, can I remove the TPS and the other sensor(think it's IAC) to clean the TB with carb cleaner without any problems? Thanks...T Quote
digitaloutsider Posted March 12, 2007 Report Posted March 12, 2007 This would do a lot better in the Powertrain section. It's not TGP-specific. I don't see anything wrong with spraying the stuff while the sensors are on. I doubt it's going to hurt them. If you can turn it by hand, then it should be loose enough to pull the rest of the way out. Put a chisel under the edge and pry it up. Quote
Pontiac6KSTEAWD Posted March 12, 2007 Report Posted March 12, 2007 Just cause it turns by hand dont mean nothing. That just means the plug is spinning while the 0-ring is still attached to the housing. Those things are such a bitch to replace. I have replaced 3 of them on my cars in the last year, and what worked for one, didnt work for any of the others. Keep playing with it, and she will eventually come out.. Quote
Garrett Powered Posted March 14, 2007 Report Posted March 14, 2007 Think I used channellocks, although cant remember. once youn get a good grip wobble it back and forth it will come out. Quote
gp90se Posted March 14, 2007 Report Posted March 14, 2007 i had a bent flat head, used it to pry the drive out, worked tits. i also use a bead of rtv at the top when placing it back in, never worry about it again Quote
89GPSE Posted March 15, 2007 Report Posted March 15, 2007 i had a bent flat head, used it to pry the drive out, worked tits. i also use a bead of rtv at the top when placing it back in, never worry about it again RTV FTW. same thing I have done on my 3.1's Quote
