PCGUY112887 Posted March 11, 2007 Report Posted March 11, 2007 Coming from the left front, when I turn a hard turn sometimes I hear/feel a pop/groan coming from right around the tire. When I jack up the car, the tire has no play if I push on the tire from the top and bottom (pushing on the sidewall not actually up to the fender and down to the road) but if I push on the left and right of the tire again on the sidewalls, it moves some and kinda squeaks/groans. What is going bad and does anyone have a picture of what I need to replace? Quote
PCGUY112887 Posted March 13, 2007 Author Report Posted March 13, 2007 Anyone? I know many of you know what it is, I just can't find jack via the search. Quote
BXX Posted March 13, 2007 Report Posted March 13, 2007 I think your ball joint is actually popping out of the socket some... Check that out.. Quote
jdcutty Posted March 14, 2007 Report Posted March 14, 2007 If you have play when you wiggle from the top/bottom of the tire, then it's your ball joint. If you have play when you wiggle from the left/right of the tire, then it's your tie rod. If you have all around play, the it is your wheel bearing. Also the clunking you hear could be a bad axle. But i would check the above three, as they are cheaper and easier fixes. Quote
FordBoy Posted March 14, 2007 Report Posted March 14, 2007 I think that the axles give more of a clicking then a clunk but it could be different on other cars then what ive worked on Quote
PCGUY112887 Posted March 15, 2007 Author Report Posted March 15, 2007 So when people say they did their tie rod on here, do they replace the whole rod or what? Anyone have a picture? Quote
jdcutty Posted March 15, 2007 Report Posted March 15, 2007 So when people say they did their tie rod on here, do they replace the whole rod or what? Anyone have a picture? NO you buy a tie rod end. the actual rod is threaded and and the end screws onto it. And if you replace it, dont forget to have an alignment done. There is one way to do it I guess to get it real close without having an alignment done. When you take the bad one off, count the number of turns it takes to get it off. Then when you put the new one on, turn it the same amount of times. That will put it in roughly the same position as the old one. Quote
