19Cutlass94 Posted March 5, 2007 Report Share Posted March 5, 2007 Yes I did search but I didnt find exactly what I was looking for. When doing the battery relocation, Im going to just wire the stock ternimals and the battery in the trunk in parallel. But for the stock terinamls that are side mount, for those who have done this, how did you connect the 4g wire to the stock ternimals? Just bolted the two together? I know I have to run the positive and the ground wires through the grommet in the firewall, then connect to the battery like you would normally do. But of course Ill prolly be adding another battery on top of that, so I would just wire up the positive to the other battery and just find a ground for it. Then hook up all my amps and such. But really back to the ternimal question, would I just bolt the all the wires together ( the ground to the factory ternimal, and the positive to the factory ternimal ) and just leave then where they are? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
AWeb80 Posted March 7, 2007 Report Share Posted March 7, 2007 just ground the neg. post to a place in the trunk.... click my www button for pics.....under the folder "battery relocation"... shorter ground the better....and you'll need a fuse too....i got a 200 amp. Quote Link to comment Share on other sites More sharing options...
