supercharger gasket
I just found a nice vacuum leak coming from betweeen my gutted supercharger case and LIM. The gasket is practically new and I think my case might not be perfectly flat at the spot where I found the leak. What would be the best sealant to try and seal this?
could you stack two gaskets atop one another? i did this once for my exhaust, and it worked great.
Red RTV?
Is it a GM gasket? I've heard they suck.
RTV should be more than enough to seal it. Just make sure it sits a day or two to make sure it sets up.
Theres some things where you can stack gaskets, like exhaust manifolds or headers, but other things you cannot stack gaskets. It wont work and itll cause more problems that what you started with.
yeah RTV for sure. do a thin bead on both sides of the gasket just to be safe.
x2 on letting it set for at least 24 hours.
arent there a couple different kinds of supercharger gaskets!?...different styles...i don't remember which one is supposed to be better than the other...i just know that there are supposedly 2 different kinds...maybe search clubgp!?...
