servoalt Posted March 4, 2007 Report Posted March 4, 2007 Hey does anyone here know of any websites that show what the codes mean on the ID plate of a 4t60e trans? I have a blown trans in my '95 CS and now I have a '96 CS trans that i might swap in, if it will work that is. I'd like to know where I can go to find out if it will work because they don't look identical. Does anyone have a hollander? Thanks Quote
3WH12-96 Posted March 4, 2007 Report Posted March 4, 2007 here is an offical GM ID ill ask round tomorrow at work what you may run into between a 96 install in a 95 this is for ID purposes only Document ID# 73069 1996 Oldsmobile Cutlass Supreme -------------------------------------------------------------------------------- Transmission Identification Information (1) Transmission ID Location (2) SRTA Tag Location (3) Hydra-Matic 4T60-E SRTA Tag (4) Model (5) Model Year (6 = 1996) (6) Control Number (7) Transmission (8) Serial Number (9) Julian Date (10) Calendar Year (6 = 1996) (11) Hydra-Matic 4T60-E ID Tag (12) Model Year (6 = 1996) (13) Line Built (1 = Line 1; 2 = Line 2; 3 = Line 3; 4 = Line 4) (14) Transmission (15) Julian Date (16) Shift Built (A = First Shift; B = Second Shift; C = Third Shift) (17) Model (18) Serial Number in Base Code 31 (19) W = Warren Plant (20) Hydra-Matic 4T60-E (21) Model (22) Transmission Vehicle Identification Number Location -------------------------------------------------------------------------------- Document ID# 73069 1996 Oldsmobile Cutlass Supreme [attachment deleted by admin] Removed to free up storage space. Quote
5speedz34 Posted March 5, 2007 Report Posted March 5, 2007 I'm going to say its not going to work because of '96 being OBD II. Quote
3WH12-96 Posted March 5, 2007 Report Posted March 5, 2007 i do agree with ya but im gonna ask ne way Quote
Crazy K Posted March 5, 2007 Report Posted March 5, 2007 the tranny doesn't care whether the car is obdII or not... especially a 96 adapted to run on a 95. I'm sure it can be done, although the connector might need repinning. iirc at some point the trannys started recieving Pule Width Modulation, and you can get buy with not hooking the wire up... But I think Brian P might have the best answer on this. Quote
Brian P Posted March 5, 2007 Report Posted March 5, 2007 it's the same tranny. You will need to transfer the '95 park/neutral/gear switch (on top) onto the new 96 tranny. What do you visually see different about it? Quote
19Cutlass94 Posted March 5, 2007 Report Posted March 5, 2007 There shouldnt be anything difference about the tranny except for many a sensor/switch or something of that nature. They are the same tranny like said above so there shouldnt be anything different. Quote
servoalt Posted March 5, 2007 Author Report Posted March 5, 2007 Yeah, the trans selector seems different to me. I'm not sure yet what else is different. This is the 1995 trans inside the car still. This is the 1996 trans with a big connector and lots of wires, but no lever. Maybe the lever was removed? Quote
Brian P Posted March 5, 2007 Report Posted March 5, 2007 yeah lever was removed. Just transfer that switch, line it up as best as you can (might have to adjust it once everything is installed and running) and use your lever. Quote
servoalt Posted March 6, 2007 Author Report Posted March 6, 2007 Are there any other different sensors on the transmission? Other than the park/neutral switch, will the trans swap right in? Quote
Brian P Posted March 6, 2007 Report Posted March 6, 2007 that's all. I'm running a '96 tranny in my '95. No other differences. Quote
pwmin Posted March 6, 2007 Report Posted March 6, 2007 Brian P said: that's all. I'm running a '96 tranny in my '95. No other differences. not exactly true. some 96's (like my old one) had a bigger tcc apply valve Quote
Brian P Posted March 6, 2007 Report Posted March 6, 2007 pwmin said: Brian P said: that's all. I'm running a '96 tranny in my '95. No other differences. not exactly true. some 96's (like my old one) had a bigger tcc apply valve Pshaw! Some '96's had a different sized gear on the diff side (forgot which one). Who cares Quote
pwmin Posted March 6, 2007 Report Posted March 6, 2007 Brian P said: pwmin said: Brian P said: that's all. I'm running a '96 tranny in my '95. No other differences. not exactly true. some 96's (like my old one) had a bigger tcc apply valve Pshaw! Some '96's had a different sized gear on the diff side (forgot which one). Who cares i did when i got the wrong one where it said 96 and older used this one and i got it and it was wrong and theyre like oh i guess some 96's got that too Quote
