Hey all,
got a 98 lumina 96k miles,
my front drivers side brakes make a treible grinding/sqauking noise when i back up my car, and the noise only happens, when the brakes are slightly pressed.
i had the brakes and rotors inspected they are in good working order, so i am at a loss
the brakes did this before but i had them replaced(pads) and the rotors turned.
thanks :question:
What kind of pads are they?
stock replacement pads , i had the brakes done a a local shop, they stop great
just noisy, on a side note , this lumina was a county inspectors car,(aka) county mantained , if that means anything
  • 5 weeks later...
Well i still have this problem , i put on new front brake pads today and the noise is twice as bay , but this thing stop great, any ideas?
please help
Ive got semi-metallic pads on my car, and they do not make any noise at all. How are the caliper slides? Are you using any shims on the back of the pads?
what are caliper slides?
no shims on the pads , they look as the do in the link,
you see it only make this loud squak noise when you back up , at no other time does it make noise.
thansk again
take the pads out and use "disk brake stop squeel" on the back of the pads and lube up the caliper slides that should solve your problems
