Garrett8 Posted February 27, 2007 Report Posted February 27, 2007 anything other than the factory ones such as l36 injectors work? Quote
pwmin Posted February 27, 2007 Report Posted February 27, 2007 i put L32 injectors on my 96 but i had to use the newer connectors. Quote
Garrett8 Posted February 27, 2007 Author Report Posted February 27, 2007 i put L32 injectors on my 96 but i had to use the newer connectors. thats what i was thinking i work at a parts store and my cost the l32 injectors cost half as much as an lq1 injector, did you notice any gains? Quote
pwmin Posted February 27, 2007 Report Posted February 27, 2007 the car ran like shit until i changed the flow rate in the pcm. i dont have any dynos of the difference. didnt notice much of a difference. shit, if forgot i have a whole set of 96 LQ1 injectors that came out of my car when i put the L32 ones in. they werent bad or anything, i just got a good deal on the L32's and decided to try them. i might be willing to sell them. Quote
Andrew Posted February 28, 2007 Report Posted February 28, 2007 when i replaced all my injectors in my 91 Z, i went to a place called 'dr. injector' and they hooked me up with modified ford injectors @ $45 a piece. they worked great too, car ran great with no pcm tuning needed. i would also look at the gm 25# injectors. they flow a little better than stock l36 injectors and are real cheap. zzp carries them for i think $125 for all 6. but i dont remember what rate the stock LQ1 injectors are so i dont know if they would work. i would think so though, zzp says they will support up to 300 crank HP. Quote
