I'm wanting to go ahead and get new tires so I can get my new wheels on sometime in march. I'm wondering what the best size tire would be. The wheels are 17x7. would a 225/60/17 work?
well if 225/60/16 are stock, then i would get 225/55/17 . they will keep your speedo nearly dead on.
x2!
would it be better to go with a 225/55/17 or a 245/45/17. I'm not really too concerned about the speedo being off, I'm more worried about the tires rubbing or hitting something
I'd run a 225.45.17 or a 245.45.17 ....I think a 225.60.17 would look like a truck tire
the wider tire you have the more likely you are to rub. however i think you are safe to run a 245 wide tire. 245/50 would be optimal to keep the speedo on, but the selection of tires in that size is super small, which is always something to consider. so i would get 245/45, the selection is much better. your speedo will be off a bit though. when your speedo reads 60, you'll really be going 58.
http://www.miata.net/garage/tirecalc.html
I went with 245/45/17, I used that calculator earlier, It wont really bother me the speedo being off by 2-3mph, I'm usually a little over anyway. New rubber should be here in the middle of the week. Now I have to get ahold of a powdercoater. I should have them on the car before spring break (middle of March) :burnout:
I know slick ran that size on his Z and never had a problem.....and before Slick got them they were on a 94-96 GTP w/o problems too
The only problem with 245/45/17s is that they need to be on a wheel 7.5"-9" wide....you said you had 7" wide.
good point, I didn't even catch that part of his post...
oh shizzle i didnt catch that either! noooo, stop your order quick!
