Crimson Fury Z Posted February 23, 2007 Report Share Posted February 23, 2007 i'm tinkering w/the idea of swapping for the LS cluster. aside from needing to install the proper rpm goodness, would the wiring harness for the base fit into an LS cluster, or would repinning be needed? if anyone has the gm manual for an Impala, could i get some scans sent my way? Quote Link to comment Share on other sites More sharing options...
Euro Posted February 23, 2007 Report Share Posted February 23, 2007 i'd think it would be the same, what does your cluster show? Quote Link to comment Share on other sites More sharing options...
Crimson Fury Z Posted February 24, 2007 Author Report Share Posted February 24, 2007 gas, speed, temp for the analog display. the door badges will be in on monday! aiming to find the police center hubs, but on e-bay for $200, nah! i'm hoping a yard around here will have a parts impala i can raid. Quote Link to comment Share on other sites More sharing options...
stockgp Posted February 24, 2007 Report Share Posted February 24, 2007 what year and model, i'll look into it Quote Link to comment Share on other sites More sharing options...
Crimson Fury Z Posted February 25, 2007 Author Report Share Posted February 25, 2007 01, thanks! Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted February 25, 2007 Report Share Posted February 25, 2007 http://www.impalahq.com The Impy gets its data stream from the Class II Serial bus, so you won't need to rearrange any wires. You'll only be able to upgrade to the cluster with the tach, gas, and temp gauges if you have the 3400. The 3400's PCM doesn't have a provision in it for the oil pressure gauge, so if you swapped in a Monte SS cluster with the full gauge package, the oil pressure gauge won't function. Won't be a problem if you have the 3800. Damn, I just saw that Impala HQ is down! Try poking around at http://www.naioa.com... Quote Link to comment Share on other sites More sharing options...
