FordBoy Posted February 23, 2007 Report Posted February 23, 2007 ...would 225/75/r14's rub on my wheelwells ? or tho off my speedo there is a nice set of rims in a j/y on a nissan pickup that was draged the bolt pattern looks right but i want to no if i could use them before i see if they will fit Quote
Q-Ball Posted February 23, 2007 Report Posted February 23, 2007 The offset will probably be different. It could be 5 bolt pattern, but how knows 5x114.3 or 5x115, etc. Quote
FordBoy Posted February 23, 2007 Author Report Posted February 23, 2007 i have 185/75/r14 on it now il find out if the bolt pattern is off when i get there im just wondering if the tire will rub if the bot pattern is the same Quote
slick Posted February 24, 2007 Report Posted February 24, 2007 The offset will probably be different. It could be 5 bolt pattern, but how knows 5x114.3 or 5x115, etc. .7 mm is hardly a difference. Either will bolt on to w's just fine. Quote
Q-Ball Posted February 24, 2007 Report Posted February 24, 2007 The offset will probably be different. It could be 5 bolt pattern, but how knows 5x114.3 or 5x115, etc. .7 mm is hardly a difference. Either will bolt on to w's just fine. Yeah I know, I was just giving that as an example. Quote
