Dirty Rockstar Posted February 23, 2007 Report Posted February 23, 2007 I also posted on 60 degree.. Just need some pointers.. I've gotten as far as the pistons.. THe oil pan is ready ot be dropped as well.. ..ANyone here pulled a DOHC apart to the bare block? What are some things I need to have in order to get the crank out for example? I want to get it torn apart but I don't want to go in too blindly.. ..The reason I am tearing it apart is to ave it honed and cleaned.. Depending on how that goes will dictate what I need to get as far as pistons go.. ..THe project overall si going by too slowly for my liking, but I had to move out into my own place faster than I would have liked.. THe car is also in my own garage now so no one can yell at me for having my stuff in their way.. I want to have this DOHC as fresh as possible so when I do go turbo (I'm holding off on the turbo because I want a 6 speed more.. And I wanna drive it!) THanks guys! Quote
pwmin Posted February 23, 2007 Report Posted February 23, 2007 sorry i dont have much to input, but im hoping to rebuild a 96 dohc soon too. the only thing ive done is taken one apart down to the block so far, no bottom end. make sure you mark all the caps as far as which cylinder. are you using the stock rods? Quote
Dirty Rockstar Posted February 24, 2007 Author Report Posted February 24, 2007 FOr now I intend to use stock internals (Unless the block needs to be bored to clean out any damage to the walls).. ..When I go turbo, forged rods and pistons will be part of the budget.. Quote
birdman Posted February 24, 2007 Report Posted February 24, 2007 well to get the crank out youll need to take the timing cover off and that means taking the timing sprocket off, thats where ive been stuck for a while now, not thats its impossible obviously but you either need a special tool, or tap three of the holes and use a puller. some people said to use a three jaw puller but i dont see any way to get it in there so good luck. Quote
Dirty Rockstar Posted February 24, 2007 Author Report Posted February 24, 2007 I dont know if youre talkin in car or not.. My DOHC is on a stand.. Quote
Psych0matt Posted February 24, 2007 Report Posted February 24, 2007 i used a puller to get that crank off, but i used a three jaw puller and only put two jaws on it, and then to keep the two jaws from popping off i used one of those clamps that has the hand pump thing to hold the two jaws together pretty much, and it popped right off. Quote
birdman Posted February 24, 2007 Report Posted February 24, 2007 mines on a stand also but the problem i had was even getting the puller around the back even a little, the sprocket is just so close i cant get one to go behind it at all. mabey you'll have better luck though. Quote
Dirty Rockstar Posted February 24, 2007 Author Report Posted February 24, 2007 I see.. Ill head to the auto zone this weekend if Im not snowed in and give a 3 jaw puller a shot.. Quote
pwmin Posted February 24, 2007 Report Posted February 24, 2007 i used a 3-jaw for the gears when i did my camaro. should work just fine. Quote
birdman Posted February 24, 2007 Report Posted February 24, 2007 well behind my timing sprocket theres mabey 3/16 to 1/4 inch clearance and thats the problem im having. Quote
Psych0matt Posted February 25, 2007 Report Posted February 25, 2007 well behind my timing sprocket theres mabey 3/16 to 1/4 inch clearance and thats the problem im having. same problem here Quote
birdman Posted February 25, 2007 Report Posted February 25, 2007 the three finger puller i had musta been different than yours because there was no way to get it even close to fit back there. Quote
Psych0matt Posted February 25, 2007 Report Posted February 25, 2007 took me about 3 or 4 hours to figure it out, but once i figured out a way to get it to work it popped right off Quote
GutlessSupreme Posted February 25, 2007 Report Posted February 25, 2007 I let the machine shop deal with getting the timing pulley off didn't want to bother. On a 3.1 you don't need to remove the timing pulley to remove the cover, only the crank/belt pulley needed to come off and I did that with a 3 bolt puller. Quote
