19Cutlass94 Posted February 22, 2007 Report Posted February 22, 2007 Today I wanted to move that red car so that I could actually have room to take some parts off it. Well I went to turn the key, and BAM!!! Nothing! Ive got no power no radio absolutly nothing! So I thought about it for a minute, them broke out the DMM and measured the battery voltage. Yupp, ive got 1.6volts! Do you I might be able to charge this up somehow? I really DO NOT want to buy another battery because I just will not use/have this car long enough to buy another battery. Quote
Robby1870 Posted February 22, 2007 Report Posted February 22, 2007 how far are you trying to move it? Quote
19Cutlass94 Posted February 22, 2007 Author Report Posted February 22, 2007 Out of the garage then back in. I cant even put it in neutral to push it. Quote
Robby1870 Posted February 22, 2007 Report Posted February 22, 2007 Out of the garage then back in. I cant even put it in neutral to push it. ? Why not? All you gotta do is turn the key to On, you don't need any electrical power to put it in neutral. Quote
19Cutlass94 Posted February 22, 2007 Author Report Posted February 22, 2007 lol then that car might have bigger problems than just the battery. Im glad Im parting it out. When I turn the key ON, I go to put it in neutral, and its like theres no key in the ignition. Quote
Robby1870 Posted February 22, 2007 Report Posted February 22, 2007 Interesting. What year is it? Quote
Crazy K Posted February 22, 2007 Report Posted February 22, 2007 lol then that car might have bigger problems than just the battery. Im glad Im parting it out. When I turn the key ON, I go to put it in neutral, and its like theres no key in the ignition. turn the key far enough? did you press the brake at the same time? Quote
19Cutlass94 Posted February 22, 2007 Author Report Posted February 22, 2007 Im pretty sure I did, but the wheel is locked all the way to the left so it could have gotten stuck maybe? Im not sure. And No I didnt press the brake because Ive got the rear calipers off the car and I dont need a bigger mess than what Ive got Quote
Crazy K Posted February 22, 2007 Report Posted February 22, 2007 Im pretty sure I did, but the wheel is locked all the way to the left so it could have gotten stuck maybe? Im not sure. And No I didnt press the brake because Ive got the rear calipers off the car and I dont need a bigger mess than what Ive got so you are saying you can't turn the key? wiggle the wheel back and forth while turning the key. seems like it's just binding. Quote
Bolt_Crank Posted February 22, 2007 Report Posted February 22, 2007 The battery is toast... you might be able to get enough juice in it to start it, but it's not gonna be likely... Quote
Dirty Rockstar Posted February 23, 2007 Report Posted February 23, 2007 You're trying to peel a banana with a blowtorch guys! Take the console out (Or just the lid), and locate the cables coming to the base of the shifter.. POp the smaller one (THis is the safety switch- Its there to prevent you from doing what I am asking you to do) off and you can now change gears in the transmission.. Quote
5speedz34 Posted February 23, 2007 Report Posted February 23, 2007 You're trying to peel a banana with a blowtorch guys! Take the console out (Or just the lid), and locate the cables coming to the base of the shifter.. POp the smaller one (THis is the safety switch- Its there to prevent you from doing what I am asking you to do) off and you can now change gears in the transmission.. You need to move the shifter back to take the console out. Why not just throw the battery in from your car? Also, I'm going to bet with the wheel locked one way that it's probably just needs to be turned while you try to start it. Quote
jeremy Posted February 23, 2007 Report Posted February 23, 2007 ]Why not just throw the battery in from your car? x2 Quote
19Cutlass94 Posted February 23, 2007 Author Report Posted February 23, 2007 I cant take the one out of my car because I need it so I can try to get the air out of the cooling system, then I need to load it on the trailer to bring it down to get an alignment. Quote
