Psych0matt Posted February 22, 2007 Report Posted February 22, 2007 So, my girls car has a weird problem. when you start it up, right as you let off the key it seems to want to catch again, and makes the loud grinding noise like when you turn the key to start it when its already running. any ideas? Quote
Crazy K Posted February 22, 2007 Report Posted February 22, 2007 bad return spring on the starter? Did you pick this girl up for her car or what? Quote
Addicted To Boost Posted February 22, 2007 Report Posted February 22, 2007 Uh it is COMPLETELY NORMAL for a loud grinding noise to be present when you try to start a car that is already running!!! Quote
Psych0matt Posted February 22, 2007 Author Report Posted February 22, 2007 Uh it is COMPLETELY NORMAL for a loud grinding noise to be present when you try to start a car that is already running!!! I know that, what i mean is that it makes that sound at the end of starting it. and no, ive been with her more or less for the last two and a half years, the car has been in the family, but shes only been driving it (aside from when she goes home) for the last two months or so, and this problem just started recently Quote
Addicted To Boost Posted February 22, 2007 Report Posted February 22, 2007 Uh it is COMPLETELY NORMAL for a loud grinding noise to be present when you try to start a car that is already running!!! I know that, what i mean is that it makes that sound at the end of starting it. Ok good... just making sure Quote
Brian P Posted February 22, 2007 Report Posted February 22, 2007 The starter gear could very well be sticking. You can narrow it down by checking if the starter solenoid is still getting juice when the key is out of "start" position, and you hear it grinding. If it's not getting power, it's not an electrical issue. Quote
Psych0matt Posted February 26, 2007 Author Report Posted February 26, 2007 little more help? i guess i dont quite understand what Brian is saying Quote
Brian P Posted February 26, 2007 Report Posted February 26, 2007 See in the hole, there's a gear off to the right side? When you engage the starter, the gear gets shot to the left to mate up with the flexplate, to turn the engine. When you let off the starter, it contracts back. Sometimes the gear can stick instead of going back. Quote
Psych0matt Posted February 26, 2007 Author Report Posted February 26, 2007 ok,i get it now, one of those "duh" moments Quote
Brian P Posted February 26, 2007 Report Posted February 26, 2007 fully understandable... it happens to all of us Quote
