Where to Install Gauge Sender on L36?
Is there any spot on a L36 (like an unused, plugged hole) to install a sender for an aftermarket coolant temp gauge? I quickly looked over the engine (what could be easily seen) and see no possibilities.
You could pry rig up something through one of the block drain plugs.
I don't know why you want an aftermarket coolant gauge.....the IPC gauges are pretty accurate and actually move on GM vechiles.
