Hi everyone I have a few questions on my 94 cutty supreme sl 3100v6. I know that the topic of the TCC. Well i have had with the tranny before but i didnt know what was wrong with it. A good example is say i am doing 45 and i hit the gas it takes a while before it picks up speed, (it is the same whether i am going uphill or not) So today i tried the touching the brake pedal while on the gas and it took off normal but as soon as you release the brake pedal it seems to fuck up again. If you hold the brake pedal just slightly it works fine. Is there any way someone can confirm this as being the TCC and maybe give me an idea of what kind of project i am getting into. Thanks in advance to all :biggrin:
I know your transmission is a bit newer, but mine shifts into OD at 45. Did you check your brake switch near the brake pedal? sometimes I hear those can be adjusted or need to be cleaned
anyone else have any similair probs with trannys on these trannys. Ok so there is a few things i might add. About 7000 miles ago i did a tranny fluid and filter change and used valvoline HM dexron mercron3 fluid, changed my plugs with autolite plugs properly gapped. changed the wires and added boot protectant, checked the coils, checked and replaced bad vacumn lines and pcv valve, air filter, you name it i changed it. Could it be possible i have bad plugs already maybe. But if there is one thing i have noticed it has done it for as long as i have had the car which is over 2 years. this is my engine 3100SFI, and Im pretty sure I have the 4T60e transmission. I would really like to get this fixed because i am so picky with things lol. Its especially bad when i am on the highway and hit the gas to have the car do nothing. Is there any way to troubleshoot this for my fully electronic tranny, and what more can i do :question: :frown: I take care of my car so well that this is the only major issue for me and i have done too much research for this
[attachment deleted by admin] Removed to free up storage space.
