so my upper rad hose got a pin hole. i replaced it. a week later on top of my water pump theres a little housing that the heater hose connects to and neways the gasket was shot and leaked all over so i replaced the gasket it stopped leaking.
another week later i get another leak.. but this time its a mystery to me..i noticed the smell of burning antifreeze i pop my hood and all i can see is that coolant is leaking from somewhere on to my belt throwin the it around on the pulley side of my engine..i can only notice most of the coolant under the water pump area.. so my question is the water pump seals around the shaft done?i understand that Occasionally water pumps will only leak around the shaft seals while the shaft is rotating. or is it the water pump gasket shot and its leaking from there.. its hard to c with all the pulleys where the leak is coming from..any suggestions on what it could be!!?? :exclaim:
r u sure...its no biggie if it is cuz i work at a an automtive service shop so i can get it at cost(mega cheap parts for me :mrgreen:) but from my explanation thats what it sounds like the issue is?
