GPdriver1986 Posted June 10, 2003 Report Posted June 10, 2003 I took out the relay of my secondary fan and put in a jumper wire but it doesn't seem to work. I took jumper wires and plugged them from battery to the fan and the fan worked perfectly. I was also reading my owners manual and it said that the overheating light is for overheating and it also tells you if the cooling fans are not working properly. Is my fuse blown? Quote
KrazyCutlass1995 Posted June 10, 2003 Report Posted June 10, 2003 my secondary only works when my a/c is on , but before i got my ac fixed i had the 2nd fan on a relay switch since my wiring was all ghetto Quote
Slade901 Posted June 10, 2003 Report Posted June 10, 2003 I've wired my 2nd fan to my 1st fan.. that way when the 1st fan runs, the 2nd fan also runs. It cools down my coolant pretty fast.. Quote
KrazyCutlass1995 Posted June 10, 2003 Report Posted June 10, 2003 I've wired my 2nd fan to my 1st fan.. that way when the 1st fan runs, the 2nd fan also runs. It cools down my coolant pretty fast.. good idea , why didnt i think of that ? :oops: Quote
GPdriver1986 Posted June 10, 2003 Author Report Posted June 10, 2003 First I probably need to check if there is power at the relay just like the manual fan switch mod in the upgrades section. Then what? Quote
SmokesGTP Posted June 11, 2003 Report Posted June 11, 2003 Slade how did you wire it up like that? Quote
NDN-Grand Prix Posted June 11, 2003 Report Posted June 11, 2003 would the relay switch for the first fan over load? and did you just connect the second fan over to the first one? Quote
Slade901 Posted June 11, 2003 Report Posted June 11, 2003 It has not overload any relay and I just connected the wire of the 2nd fan to the 1st fan wire (using an extension wire between the 1st fan wire and 2nd fan wire). I've have it this way more than 3 years now. It's like a C-130 taking off when the fan turns ON Someone said that here about their fan before. Quote
NDN-Grand Prix Posted June 12, 2003 Report Posted June 12, 2003 You must get a little more speed with the air your pulling in. lol Just kidding. Quote
