Ok 93 cutty is at 200k mark and I noticed that sometimes when I shifted the car would not go into gear for a few moments so I changed the filter and fluid and that seemed to fix the problem but a few days later I noticed that when I took off in drive the car would shudder and slip unless I accelerated slowly or manually shifted. I unplugged the TCC and the car runs fine except now I don't have OD. Can any of you tell me what part number the TCC is I have looked around and there are several different types.
STANDARD MOTOR PRODUCTS Part # TCS21 {TRANSMISSION CONTROL SOLENOID}
Two used, replace as required.; Front Wheel Drive; 4 Speed Transmission; Shift Control Solenoid
Front Wheel Drive; 4 Speed Transmission; Torque Converter Clutch Solenoid
$10.96 $0.00 $10.96
STANDARD MOTOR PRODUCTS Part # TCS35 {TRANSMISSION CONTROL SOLENOID}
Torque Converter Clutch; Pulse Width Modulation Solenoid; Front Wheel Drive; 4 Speed Transmission
$41.79 $0.00 $41.79
ACDELCO Part # 24202614
VALVE,TCC SOL USED AS SOL"A",SOL"B" & SOL TCC/VCC QTY 1 EACH; w/4-SPD A/TRANS(M13)
$9.86 $0.00 $9.86
ATP Part # JE1 {HARD PARTS-TCC SOLENOID (PWM)-TRANSAXLE / OE# 8683535 #8683535}
4T60-E, 4T65-E; FWD; 4T60-E; TCC SOLENOID (PWM)
$21.79 $0.00 $21.79
ATP Part # CE4 {HARD PARTS-LOCK-UP SOLENOID-TRANSAXLE / OE# 8689901, 8685465, 8689902 #8689902}
TH-125 (3T40); FWD; LOCK-UP
$22.79 $0.00 $22.79
ATP Part # CE2 {HARD PARTS-1-2, 3-4 SHIFT SOLENOID-TRANSMISSION / OE# 8683082, 24202614, 8683081, 10478108, 10478120 #24202614}
4T60-E, 4T65-E; FWD; 4T60-E; TCC/VCC SOLENOID (NOT PWM)
4T60-E, 4T65-E; FWD; A & B SHIFT SOLENOID
$30.89 $0.00 $30.89
ACDELCO Part # 8689902 {#08689902}
VALVE,TCC SOL w/3-SPD A/TRANS(MD9)
$31.79 $0.00 $31.79
Control Unit
These are off Rockauto.com
