switched out alternator and battery
had to replace the alternator and battery in the monte...never again am i doing that.
alternator had 150,000 miles and when i pulled it off it growled at me when i spun the pulley... must not have wanted to stay under the hood any longer, but at least i got the $50 core charge out of it and the new one cost $180
battery was 7 years old and now i got a duralast gold that puts out some 700CCA
also replaced the serpintine belt
who the hell came up with the idea to make cars that have about 1/64th of an inch of room to get a wrench behind the alternator? if i have anything else major to do on this thing its going to somebodys garage or its going to pull a houdini or i'm yanking the motor to make some kind of monster fuel injected quadracer... LT3100R :smile:.
anyone else had the pain of replacing the alternator lately(and on the coldest day of the year)?
Gotta be the 3.4. Did you follow my write-up on the alternator repair? It makes it a ton easier.
BTW, I woulda went for something larger than 700CCA. In fact, always try to fit the largest that you can.
This summer I changed my alternator took me two days,not the best spot to be working in.It is a 3.4 monte z-34,I know what you mean about that nut behind the alternator,had a few choice words for it.I did follow the write-up sure helped me.
Eh, the pros outweigh the cons when it comes to the LQ1.
I agree!!!! Even when it comes to working on it.
which car/engine?
95 monte l82(3100) still took forever even though it sounds like the DOHC guys have it rougher than me
which car/engine?
youre kidding, right? the alternator on those is like eating cheesecake compared to anyone with an LQ1, which is more like chewing on metal shavings :lol: Ive actually never done mine before, but that's cuz i couldnt for the life of me break one of the subframe bolts loose. I found out the shop that I took it to dropped the rear or the subframe, not one side, so ill try that if/when i hopefully never have to try it
