LED's Installed! (Pics Inside)
I just installed my interior and license plate LED's over the weekend so I thought I would show them off. What do you think? There 5 LED Matrix and 9 LED 44mm Festoon from autolumination.com.
They dont seem too bright. One thing I dont like about LED's is, that you have to look at them straight on to be bright.
They are for sure brighter than stock. At night you can see everything inside the car.
i'm going to redo all my interior lights eventually as well. the LEDs look classy at night when you open the door
X2
Instead of that amber eyesore you get a really nice blue (or whatever color you want) I love them.
i have blue gel sleeve type things on all my lights, matches the color of the cluster and stuff. ive always liked it, even though it is a tad ricey :dunno:
Are these wide or narrow angle LED's?
Either way, I'd like to do the same sometime. I'm assuming these were pop-in, replacement style fixtures, that you didn't have to solder a group of led's and resistors together, correct?
They're wide angle and yup you just pop the stock bulb out and pop the led in. Takes maybe 10 minutes to do everything.
If you want the light from the led's to get a little diffused, as opposed to having a bright and defined hotspot, you can sand the tip of it down. 100-200 grit seems right for this.
