seat belt and fuel light
My seat belt light and my fuel light don't come on when you turn the key to the on position. The bulbs are fine, I'm not sure whats wrong. My fuel is low but I think it will turn on later once there is less fuel. I was looking for wires going to the seat belt to try to fix the problem with the seatbelt light but I couldn't find any. Can anyone help me?
Double check fuses.
There could be one blown; read your owners manual to check which fuse it could be.
Does you warning chime ring with the lights on while driving?
- RedFox340
My chime works perfectly. I think my fuses are good because everything in the car works great, by the way its just the base model no options
Check the seatbelt harness connecter for that particular light, very common to get corrosion in the connector, Should be under the carpet next to where the seatbelt bolts to the floor.
I have the 6 passenger Grand Prix. When I looked for the cable I couldn't find it. I thought that maybe the seat belt light turns off when you pull the seatbelt out of the door since there are wires going into the door and I don't have power locks or power windows.
