Cutty Hertz Posted June 8, 2003 Report Posted June 8, 2003 Will the sheet metal fro a GP fit a CS? The underlying body is so close to the same, so in basic thoughts the front-end from a Grand should pretty closely bolt right up? Quote
Redfox340 Posted June 8, 2003 Report Posted June 8, 2003 Bolt up will be the same, since it's the same frame. However, you'll get a different look. If exchange fenders from different W-Bodies, you won't have a flush or even correct fit for light housings / etc. - RedFox340 Quote
GnatGoSplat Posted June 9, 2003 Report Posted June 9, 2003 It won't fit flush at all, the fenders and doors are differently shaped. CS has a little bit of a "shoulder", GP doesn't. CS is also bulgier on the sides. It definitely wouldn't work unless you cut the rear half of a CS fender and graft it onto the front half of a GP fender and blend them into each other. Quote
