2000GPGT Posted January 26, 2007 Report Posted January 26, 2007 Hello all, I have a 2000 Grand Prix GT that I use for my daily commuting but lately it has begun to surge when I am in a light to mid acceleration (Usually between 1700 and 2200 RPM) you can actually watch the tach jump back and forth 200, 300 and sometimes 400 rpm. I don’t think that this is a fuel problem because when I hammer on the throttle the car drops a gear and before I know it I have more than exceeded the speed limit (I also just changed the fuel filter). The car doesn’t misfire, just changed the plugs and wires about 4 months ago, and it doesn’t really feel like a misfire when it occurs. (most noticeable when climbing a hill) Just thought some one may have had a similar problem with the 3800 series engines. Any thoughts would be of a big help (and may prevent me from burning the car out of frustration) Rob Quote
Andrew Posted January 26, 2007 Report Posted January 26, 2007 Try cleaning your MAF. its quick, cheap and easy to do. MAF cleaner only(dont use TB or carb cleaner), and you'll need security torx bits to pull it. do you have a k&n air filter? if so, some of the oil can coat the MAF which will cause it to read funny. If its not this, it may be the TPS. Quote
2000GPGT Posted January 27, 2007 Author Report Posted January 27, 2007 Hey Thanks man, I removed the throttle body and cleaned everything up, tested the TPS and reset the computer. So far it has done the trick , drove 60 miles with no surging! Hopefully this keeps up Thanks again Quote
Canada Posted January 28, 2007 Report Posted January 28, 2007 Could also be a problem with your torque converter clutch.....slipping and catching.......if you crowd the TCC up hill, the Beretta's 4T60-E does it.....lightly hold the brake with your left foot to kick the TCC off...rpms rise and it goes away. Quote
rockfangd Posted January 28, 2007 Report Posted January 28, 2007 ok so i have a question. when i am driving my 94 cutty especially uphill and i am going a steady speed like 45mph with 1500 rpms and i hit the gas nothing really changes. after a bit of delay the rpms pick up and the car picks up speed. it does this anytime i am doing a steady speed . When i hit the gas from a stop i can really spin the tires but when im driving and i hit the gas it doesnt pick up speed as well as i believe it should. its a 3100 though [attachment deleted by admin] Removed to free up storage space. Quote
rockfangd Posted January 29, 2007 Report Posted January 29, 2007 is this normal, and if its not what do i do to fix it Quote
PCGUY112887 Posted January 30, 2007 Report Posted January 30, 2007 I am having a similar issue as the thread starter here is having. I personally believe it's the transmission with mine. I took it to the shop, however it wouldn't do it for them. The tranny guy swears that if the tranny starts slipping, I will get an SES light. Till then he doesn't believe anything I tell him. Quote
rockfangd Posted February 1, 2007 Report Posted February 1, 2007 yeah well what mechanics dont realize is that no 2 cars are alike Quote
