slick Posted January 23, 2007 Report Posted January 23, 2007 So.... since the new vehicle does have a 3800, I figured I would go ahead and replace the stock alt with something that has a bit more umph to it. I know there are several on here that have had HO alternators, and I've heard mixed reviews. Basically, I would like to know which brand you have gone with and your experience with them. I have found about 6-7 different companies that I know that make HO alternators, and I also know I can get one rebuilt locally(not sure if HO or not). The prices I see range from $150-$450(I know the $450 is proven to work damn good). So, lets hear em! Quote
slick Posted January 23, 2007 Author Report Posted January 23, 2007 BTW, does anyone know offhand if the alternator is a CS-130D or something other in my application? Quote
slick Posted January 23, 2007 Author Report Posted January 23, 2007 http://www.highoutputalternator.com/ I submitted for a quote for my car. Aparantly it has the GM AD230 alternator. According to this PDF: http://www.highoutputalternator.com/PDF/Web%20PDFs%20-%20230.pdf , it will put out 120 amps at idle speed. It has a turn on speed of 500 rpm, which is fine. Looks like around a 220-225 amp output max, which is fine for me. I figure stock the vehicle uses around 90-100 amps. My current amplifier pulls right between 70-90 amps, and I plan on picking up another amplifier here soon for a set of components(so... like 30-40 amps). This means I'm looking around a total of 210-230 amps, so this may be right about the range im looking for. Obviously the amps pulled is at max power, and mine are never that high, so I did overguesstimate by a good amount, but I want to play it safe. Quote
Andrew Posted January 23, 2007 Report Posted January 23, 2007 You have got to be the only person to respond to their own post, twice, before anyone else does. So are you picking one up from them? If so give an update after a couple months of running it. And let us know the price of course. Quote
19Cutlass94 Posted January 23, 2007 Report Posted January 23, 2007 Well you know my opinion about them! But really, I pulled a 144.5dB, thats on the STOCK 100amp alt. and thats with the other amp for my components running at max as well! So if I took out the fuse for the amp for my components, I would have done better. Really, unless your going to be doing SPL comps like everyday or need some ungodly demand for electrical power, I dont think you should get one. I mena if you have your system going, your lights will still dim at idle and low engine speeds, until the rpm goes up. Quote
digitaloutsider Posted January 24, 2007 Report Posted January 24, 2007 off topic, but do you have any pictures of the Bonne? Quote
slick Posted January 24, 2007 Author Report Posted January 24, 2007 off topic, but do you have any pictures of the Bonne? Not yet, still sitting in my dads driveway 2 hours away. I will get some when the Acura is gone. Well you know my opinion about them! But really, I pulled a 144.5dB, thats on the STOCK 100amp alt. and thats with the other amp for my components running at max as well! So if I took out the fuse for the amp for my components, I would have done better. Really, unless your going to be doing SPL comps like everyday or need some ungodly demand for electrical power, I dont think you should get one. I mena if you have your system going, your lights will still dim at idle and low engine speeds, until the rpm goes up. True, the but the Acura's stock alternator is 105 amp, and even driving along at a 2000 rpm cruise, the lights would STILL dim pretty significantly. My Directed amp pulls some serious amount of current, hence my thought of needing a higher amp alternator. Quote
slick Posted January 24, 2007 Author Report Posted January 24, 2007 Fuck me!! Highoutputalternator.com wants $570 + shiping for a 200 amp alternator! I found a 160 amp on www.knukonceptz.com(great place to buy wire BTW) for like $290. Quote
slick Posted January 24, 2007 Author Report Posted January 24, 2007 Here's another site. $190 + shipping for a 140 amp alternator http://www.alternatorparts.com/ad_alternator_order_page.htm Quote
19Cutlass94 Posted January 24, 2007 Report Posted January 24, 2007 Here's another site. $190 + shipping for a 140 amp alternator http://www.alternatorparts.com/ad_alternator_order_page.htm FYI, thats where I got my alt from for my car. Dont do business with them. Quote
slick Posted January 24, 2007 Author Report Posted January 24, 2007 Here's another site. $190 + shipping for a 140 amp alternator http://www.alternatorparts.com/ad_alternator_order_page.htm FYI, thats where I got my alt from for my car. Dont do business with them. Oh really, alrighty then. I'll check elsewhere. Quote
KCFITZ78 Posted January 24, 2007 Report Posted January 24, 2007 These HO alts only raise amps and not voltage right? Higher voltage and cause problems. Quote
Puggsley456 Posted February 12, 2007 Report Posted February 12, 2007 I have heard decent reviews about Excessive Amperage alternators. http://www.excessiveamperage.com/ Quote
slick Posted February 12, 2007 Author Report Posted February 12, 2007 I have heard decent reviews about Excessive Amperage alternators. http://www.excessiveamperage.com/ As have I. I think I got a price quote from them a while back, but now I forget. Quote
Brian P Posted February 12, 2007 Report Posted February 12, 2007 Go grab one from a late '93-95 3800 minivan. Some of them got the 140 amp alternator. Quote
Robby1870 Posted February 12, 2007 Report Posted February 12, 2007 Go grab one from a late '93-95 3800 minivan. Some of them got the 140 amp alternator. Sure enough. I just looked at Advance's site. They had 105A and 140A alternators. Quote
slick Posted February 12, 2007 Author Report Posted February 12, 2007 Oh cool! I'll check that out also. Quote
Brian P Posted February 13, 2007 Report Posted February 13, 2007 damn right. Don't waste your money on aftermarket halfassed alt's with extra windings shoved in there. Worst you might need is a different plug for the minivan alternator and I think the charge wire has a larger eyelet. No biggie. Quote
