gmrulz4u Posted October 6, 2002 Report Posted October 6, 2002 Is there a way to make it so that your alternator puts out more power/amperage at low RPMs/idle?? I don't really understand the whole "pulley" thing, and how this would help, if at all?? THANKS:o) http://www.worldzone.net/auto/olds/owners/brewer.html Quote
Guest Posted October 6, 2002 Report Posted October 6, 2002 I believe the "pulley thing" would in fact give you less alternator output and not more. The intention there is to put a smaller pulley on the engine - hence less net loss of h.p. due to accessory load. Smaller pulley = less drag. There is high output alts out there. Quote
Jeorge Posted October 6, 2002 Report Posted October 6, 2002 put a berreta pully on the alt If I rememberisd a 1/4 inch smaller and would spin faster making more power Quote
musthavemuzk Posted October 12, 2002 Report Posted October 12, 2002 wouldn't it just make more power at idle? as the stator inside it will limit the amps it puts out. right? Monty Quote
RedZMonte Posted October 14, 2002 Report Posted October 14, 2002 its like gear ratios. if you go with a larger pully it will spin slower. if you go with a smaller pully it will spin faster. think of a wheel. a smaller wheel will have more rotations in any given distance then a larger wheel. so if you put a Under drive pully (smaller) on your alt it will cause it to spin faster even though the belt is still moving at the same speed. Hope that makes sense. RedZ Quote
