TB coolant ByPass '92 3.4
Has anyone done a throttle body coolant bypass on the 3.4?? I'm drawing a blank as to how to do it since the TB is cast into the plenum. Which is also kicking my ass trying to clear the EGR passage that's completely clogged.
I cant help you on the 3.4 with this one, although I did it on my 2.8 cavalier, and it was just simply a piece of hose that went in place of the TB
Thats all it is, just find the in and the out. one is on the bottom, can be a royal pain to get at. I thought about doing this, but I have my doubts I would notice any differance at all.
Jamie
Jamie
I never noticed any difference in the Cav, even in the winter. I guess in a very cold climate it wouldnt be a good idea, but otherwise I was just kinda curious. it did seem to run a few degrees cooler, but a few was like 1 or 2, so hardly any difference to even be worth the 5 minutes it may take
I did it on the Cutlass when I owned it. The reason I did it is simply its easier to pull shit apart since those hoses and the clamps are a pita.
You really can't do it on the 3.4 since coolant runs through that hose out the tb to the lim and then back into a heater hose. I wouldn't even mess with it. You would have to reroute alot of hose and piping just to get it to work right.
I did it on my 3.1 only because it was a bitch to get on otherwise. No difference that i am aware of. Still warmed up fast. Sorry i can't help more.
