Philsz34 Posted January 14, 2007 Report Posted January 14, 2007 i have a 1992 chevy lumina z34 with the 3.4 DOHC. i am woundering what tranny is that and what can i get one out of. also does a 3.1 1990 oldsmobile have the same tranny? Quote
White93z34 Posted January 14, 2007 Report Posted January 14, 2007 assuming that you have an automatic, you have a 4t60e. a trans from a 3.1 cutlass would be a 4t60 - not compatible. best bet for interchangeability is a 91-93 3.4 lumina, grand prix or cutlass supreme a 94 trans can work but i know a lot of the electronics have to be changed over. Quote
The Master Posted January 14, 2007 Report Posted January 14, 2007 If you go to the Lumina page it says 125C. (W-body main page, the cars, 1990-1994 Chevy Lumina 2-door). Is this a typo that should be changed? Phil is your transmission 3 or 4 speed? Does it have overdrive? Quote
3WH12-96 Posted January 14, 2007 Report Posted January 14, 2007 how come no one has voted yet?? Quote
digitaloutsider Posted January 14, 2007 Report Posted January 14, 2007 It's a 4T60E. That's all the LQ1's ever came with as far as an automatic goes. The 125C was never mated to the LQ1. Quote
Euro Posted January 14, 2007 Report Posted January 14, 2007 The Master said: If you go to the Lumina page it says 125C. (W-body main page, the cars, 1990-1994 Chevy Lumina 2-door). Is this a typo that should be changed? Phil is your transmission 3 or 4 speed? Does it have overdrive? the 125C was only used in 90 IIRC. It was the base tranny for the 3.1 aside from the 4T60. Every 3.1 after 90 got the 4T60, til late 93 when they got the 4T60E. since his trans is the 4T60E, its the 4 speed with over drive. And IIRC, isnt the normal 4T60 without overdrive? Quote
3WH12-96 Posted January 14, 2007 Report Posted January 14, 2007 no the 4 in 4t60 means four speed Quote
Supreme Cutlass Posted January 14, 2007 Report Posted January 14, 2007 Eurosport94 said: The Master said: If you go to the Lumina page it says 125C. (W-body main page, the cars, 1990-1994 Chevy Lumina 2-door). Is this a typo that should be changed? Phil is your transmission 3 or 4 speed? Does it have overdrive? the 125C was only used in 90 IIRC. It was the base tranny for the 3.1 aside from the 4T60. Every 3.1 after 90 got the 4T60, til late 93 when they got the 4T60E. since his trans is the 4T60E, its the 4 speed with over drive. And IIRC, isnt the normal 4T60 without overdrive? Had to be longer than that.. My car came with the 3 speed Quote
Crazy K Posted January 14, 2007 Report Posted January 14, 2007 Eurosport94 said: The Master said: If you go to the Lumina page it says 125C. (W-body main page, the cars, 1990-1994 Chevy Lumina 2-door). Is this a typo that should be changed? Phil is your transmission 3 or 4 speed? Does it have overdrive? the 125C was only used in 90 IIRC. It was the base tranny for the 3.1 aside from the 4T60. Every 3.1 after 90 got the 4T60, til late 93 when they got the 4T60E. since his trans is the 4T60E, its the 4 speed with over drive. And IIRC, isnt the normal 4T60 without overdrive? of all the things. I did see a 93 GP with a 3 speed transmission. I was looking for a 93 3.1 ecm, and it had the 92 down ecm. so I thnk the 125c was still alive and well. (unless it is a different tranny?) the tranny is a 4t60e the non E 4t60 was never couples to the LG1, as said. I suspect a 93 3.1 4t60-e transmission would work fine, if that were all you could find. Quote
BIGBULS Posted January 15, 2007 Report Posted January 15, 2007 Be aware that you'll need to get an LQ1 4T60-E. LHO powered cars had a 3.33 FDR vs the LQ1's 3.43, and with their trans in place, your car will be shortshifting even more than it already does since the shifts are mph based (which will combine with the longer gearing to make it SLOW). Quote
Cam'ron Posted January 17, 2007 Report Posted January 17, 2007 i didnt know so i voted for . i thought it might have been . but i decided to go with . in the end. Quote
IRONDOG442 Posted January 17, 2007 Report Posted January 17, 2007 nametnom said: i didnt know so i voted for . i thought it might have been . but i decided to go with . in the end. LOL indeed same issue here. Quote
