after i park my car and put it in park it will kinda jump forward a little bit slowly i was thinking maybe its the trans mount but im not sure any comments? the car has 184k miles on it
Thats quite normal for any automatic car. The parking Pawl hasnt reached the stop end gear, so it rolls a little bit until it gets there. I just use my parking brake, I dont like putting the stresses on the motor/motor mounts.
:werd: Next time you park, the car, put it in neutral, apply the parking brake, then shift into park. Problem solved.
Most of the sway is from the upper torque struts.... It's normal. But if it seems excessive, replace the torque struts...
you mean... that slight movement is bad for all the mounts? I don't plan on keeping my engine long and all, but I'm gonna start using my parking brake!
Jamie
how much is excessive?
i dont see it being bad for the mounts unless the car is on a big hill or something and slams into the stop pins. little creep on flat ground 2-3 inches isnt gonna hurt anything
i always put my ebrake on when i park, just to avoid that...just put the ebrake on before you shift the car into park...
uhh...doesnt ding...just put foot on brake til you stop, then push ebrake in with other foot, then shift to park...:lol:
I wish it would ding when you left the parking brake on... When I installed my subs the power cable was in such a place that the next time I stepped on the parking brake it fell into the assembly. When I let off the brake again the cable got in the way and stopped it from releasing completely. I went for a drive and noticed the car was a bit slower than usual, and it had that funny smell of burning brakes. So I pulled over and sure enough my rims were nice and toasty. Lesson learned, the power cable isn't anywhere near the brake assembly now.
Jamie
mine dings if i am in gear and push the ebrake... i dont know about you "pontiac" :lol: but my chevy does
so... I looked at a 70's cadillac one time (and my dads 72 lincoln) both had vaccum selonoids to release the brake. Should I try one is in a W?
its definetly not normal my o4 grand am doesnt move when i put it in park either does my e250 work van and they are both auto's
its annoying it will move id say about 6 inches or so
ive never bene in a auto car and not had that
same here. no ding for me. i do the neutral/e-brake thing all the time in a slow drive-thru.
What's so hard about using your parking brake anyway?
The Regal dings in everything but park and neutral.
My friend's '05 Grand Am has about 26k miles on it and his ebrake doesn't work anymore cuz he ALWAYS uses it when he parks..It worked perfectly when he got it w/ 22-23k on it.
The only place I could find understandable where he would need to use it is his driveway, as it is kinda steep..
Oh and he still pulls it up when it doesn't even work :lol:
Same situation w/ my dad's Tahoe.
That should be covered under warenty (the e-brake cable). I would be getting that fixed, especially on a GA, they have enuf problems with the front end, dont need to add parking stress to it.
