Philsz34 Posted January 10, 2007 Report Posted January 10, 2007 replacing tranny in 1992 3.4L DOHC chevy lumina z34. need persona;l info on it. Quote
Crazy K Posted January 11, 2007 Report Posted January 11, 2007 age: 14, sex: yes please, location: living under the hood. Has a sexual fetish for hot asphalt, likes cool summer nights, long drives in the country. pet peeves: stop and go traffic, heat, antifreeze, and you... apparently. how about more info. what went wrong why has it gone bad? And I would really really really like to know if instead of installing a 3.43 (oem for 3.4) ratio tranny if a 3.33 (oem 3.1/3100) can substitute and work fine with OBD 1? Something I may consider with my own 95 CS, should it eat a tranny.. Quote
slick Posted January 11, 2007 Report Posted January 11, 2007 Ken, yes you can do it. The speed may show incorrect though. Quote
Crazy K Posted January 11, 2007 Report Posted January 11, 2007 Ken, yes you can do it. The speed may show incorrect though. the speed will not, actually. the VSS sensor detects the final output speed at the differential, which is coupled 1:1 with the wheels. I understand you cannot do this in an OBD 2 car as it will think the tranny is slipping due to a mismatch of RPMs and speed. but for his car, running a 3.33 FDR tranny coupled to a 3.4 would lower the shift points but would make the car more fuel efficient in the long run... and mine with OBD 1.5...... I guess I will just have to try it! Quote
