CNBZ34 Posted January 10, 2007 Report Posted January 10, 2007 2 Questions: What is the flow rate in the stock Injectors for the 92 Z34? Reason I ask is that I can get ACCEL replacement injectors for a good deal but they offer 24 Lb and 30 Lb. Being that I have a 97 crate engine, i thought that the 30's would benifit the runability but afraid of over fueling. Second.... Any feed back on ACCEL Injectors? Quote
BXX Posted January 10, 2007 Report Posted January 10, 2007 Here ya go, hope this helps http://store.summitracing.com/partdetail.asp?autofilter=1&part=ACC%2D150621&view=1&N=700+4294908216+4294907614+4294924927+4294840048+0 220cc/min Quote
intern8tion9l Posted January 10, 2007 Report Posted January 10, 2007 won't you need some chip work to run injectors that big? Quote
BXX Posted January 10, 2007 Report Posted January 10, 2007 220cc/min is stock flow rating for the LQ1 I found this however http://60degreev6.com/showthread.php?t=34577 Quote
CNBZ34 Posted January 11, 2007 Author Report Posted January 11, 2007 So, New ACCEL injectors have been ordered, be here next week. Will be stock 21 Lb flowrate. Almost have the plenum removed. Too cold to work in unheated garage next few days. Once plenum is removed, going to take it in and have it tanked to remove gum and varnish inside as well as carbon cleaned from EGR port. Might even get it powdercoated while I'm at it. Car should run awesome when reassembled. Any suggestions of things to do while I have the plenum removed? Quote
BXX Posted January 11, 2007 Report Posted January 11, 2007 You oughta just go ahead and do the LIM gaskets since you are there... Other than that, just clean the hell outta everything and inspect all wiring, connectors, and vacuum lines and such... Quote
Dark Ride Posted January 11, 2007 Report Posted January 11, 2007 Isn't there a Distributor O-Ring that usually goes bad on the LQ1s? I believe its like 3 bucks and is really easy to do while you are at it. Quote
CNBZ34 Posted January 11, 2007 Author Report Posted January 11, 2007 This is a crate engine with only 30k since install. Upper plenum was not cleaned good when installed then. No need to disturb either at this point. Quote
BXX Posted January 11, 2007 Report Posted January 11, 2007 Oh, thats true... I thought it wa a higher mileage engine.. I take it new injectors weren't purchased along with the crate engine?? Quote
CNBZ34 Posted January 11, 2007 Author Report Posted January 11, 2007 I bought it this way. Unfortunately, when new engine was installed, all accessories from old engine were just removed and re-installed. Install was done very well, but I would have gone the extra step to have had the upper and lwr intake cleaned and a few other things. I suspect that after this, car should run very good with a noticable improvement. Quote
Dark Ride Posted January 11, 2007 Report Posted January 11, 2007 if you got an engine with that low of miles i can't imagine it needing anything else. Should run well. Quote
asonofabeach69 Posted January 11, 2007 Report Posted January 11, 2007 so what kind of "mods" would make it worth it to run a bigger injector then stock? Obviously you'd need some kind of computer tuning. Quote
BXX Posted January 12, 2007 Report Posted January 12, 2007 Isn't there a Distributor O-Ring that usually goes bad on the LQ1s? I believe its like 3 bucks and is really easy to do while you are at it. Actually, the LQ1 has to have the heads ripped off to gain access to it... I read it in a repair manual somewhere Quote
Andrew Posted January 12, 2007 Report Posted January 12, 2007 IIRC there are a couple guys on here that have replaced that o-ring without removing the heads. so what kind of "mods" would make it worth it to run a bigger injector then stock? Obviously you'd need some kind of computer tuning. Thats about it really, as long the injector isnt longer than factory injectors. But swapping in higher flowing injectors isnt worthwhile unless you are running a power adder IMO. Quote
CNBZ34 Posted January 12, 2007 Author Report Posted January 12, 2007 so what kind of "mods" would make it worth it to run a bigger injector then stock? Obviously you'd need some kind of computer tuning. I did not buy larger injectors, I bought stock flow rate injectors. 21Lb flow. I wish not to start horsing around with custom tuning of the prom as I don't want to ruin the drivability of the car. That's why I have my '70 ranchero....Old School and easier to mod and tune. This is my commuter for work. Just want it to run as good as it possibly can stock. With the exception of exhaust mods, wheels/tires and brake upgrades this spring...it's stock. Quote
FordBoy Posted January 12, 2007 Report Posted January 12, 2007 Isn't there a Distributor O-Ring that usually goes bad on the LQ1s? I believe its like 3 bucks and is really easy to do while you are at it. Actually, the LQ1 has to have the heads ripped off to gain access to it... I read it in a repair manual somewhere The distributer is on the top of the block. not the heads. Did you mean to say valve covers cause they have to come off for LIM. It can be done without taking off the LIM but its not easy the LIM really gets in the way. Let me know how those injsctors work out for ya i might have to invest in some. i got a bad mis. I dont know if its a injector or coilpak possible the valve that is starting to go. Quote
