chevy1 Posted January 9, 2007 Report Posted January 9, 2007 what is Wheel Alignment to my Olds Cutlass Internationale 1989 2.8V6??? Iam looking for Tech data to do proper wheel alignment Quote
19Cutlass94 Posted January 9, 2007 Report Posted January 9, 2007 I hope this will help in what your looking for. I can give you the geometry from when my car got an alignment, I hope itll help. Both Left and Right FRONT Camber, Caster, Toe have the same specified range, Camber - +0.2 to +1.2 degrees Caster - +1.5 to +2.5 degrees Toe - -0.10 to +0.10 degrees Total for FRONT specified range Cross Camber - -0.8 to +0.8 degrees Cross Caster - -0.8 to +0.8 degrees Total Toe - -0.20 to +0.20 degrees Both Left and Right REAR Camber, Toe have the same specified range, Camber - -0.4 to +0.6 degrees Toe - -0.20 to +0.10 degrees Total for REAR specified range, Total Toe - -0.40 to +0.20 degrees Thurst Angle - -0.15 to +0.15 degrees Quote
chevy1 Posted January 9, 2007 Author Report Posted January 9, 2007 [quote author=19Cutlass94 thanks but it will work in my '89 cutlass????????????????? Quote
19Cutlass94 Posted January 9, 2007 Report Posted January 9, 2007 http://www.caesionline.com/wheelalign/specs/oldsmobile2.html yours is down the chart a little bit. Quote
chevy1 Posted January 9, 2007 Author Report Posted January 9, 2007 http://www.caesionline.com/wheelalign/specs/oldsmobile2.html yours is down the chart a little bit. just thanks second time you(members of this forum) are great Quote
