spark plugs cause a no start?
I have been thinking about the problem my car has been having and trying to remember what i changed when it started not starting or at least being hesitant to start after i have driven it up to temp and let it sit. the problem just came from nowhere in mid winter and has done it since. the only thing i can think of that i changed even around that time is the spark plugs. went from autolites to the cheap delcos. could those plugs cause those problems? its kinda a longshot but i dunno. thanks.
Is it possible you bent one of the electrodes on the new plugs? I've had that happen before where the car ran shittier after I changed the plugs, only to pull the plugs again and find one with the "strap" smashed in...
Is its possible that the plugs can cause a car to not start. Like said above maybe the gap was wrong, but still its kind of a longshot.
I have the same problem as birdman, and plugs don't do anything, I have changed them 3 or 4 times now and I still get that problem. I have tried different gaps....nothing to do with a no start condition. Even if the gap way wayyy off it owuld still start. If one or even two plugs were crappe dout it would still start. Plugs=no problem.
My TGP had the no start issue, if I sprayed a little carb cleaner/starting fluid/rubbing alky into the intake, it would fire right up and have no problems. once it warmed up, it would be fine for a good while. Check the grounding, make sure they're not corroded, and you might want to do a compression check, just to make sure it isn't something more serious.
ill check the grounds but if theres a compression prob ive already got another motor im building so i wont mess with it. thnaks.
that sounds like what mine is doing, but mine is a 3.1, Does it have any problem while you are driving it? any bucking or stalling?
if you having bucking/stalling while driving, you have a bad coil or ICM, but if its only when starting, not usually a symtom
your TGP had a no start issue because it had a shorted fuel pump wire that put a hole in my block :damnit1:
LOL I was waiting for you to chime in. it had the proper pressure at the rail the no start was something out. Had I had any clue about that shitty wiring, i would have repaired it when I did the pump with a 1/2 tank of fuel :sad:
drives fine dosnt stall or buck only after up to temp and has sat more than 30 min and less than 2hrs. and the icm and coils were replaced
Bump for you man, I wanna know what the problem is I have the same one. Anyone?
the one thing i think it may be but havent messed with is the FPR. its too cold and rainy to mess with it but i just have a suspicion that it may be the problem.
It could be actually......I wonder how much one is?
70-90 bucks. im going to get a new one and go over all the vac lines because its really coming down to that.
not hard to test, one easy way is to get a piece of tubing that fits snuggly over the FPR vacuum fitting, suck on it and see if there is any fuel smell, which would indicate a bad diaphragm. I changed the one on my TGP, didnt fix it but good luck.
I still have weird idle problems, sometimes it stalls when I put it park too. It's making me super mad.....AND it idles higher when it's warm than it does when it's cold on startup.... :rolleyes:
