Technics Posted January 4, 2007 Report Posted January 4, 2007 Fit perfect thanks for the help. The yard which I got it from has a couple of Beretta GTZ? and a bunch of Cadillac STS all are equipped w/ STB's could they be modified to fit W-body's? I'm thinking of purchasing an STS one and using it for my rear brace.Taking a section out of the middle welding it back together so that it fit's the rear towers. Opinions??? Quote
97loudcut Posted January 4, 2007 Report Posted January 4, 2007 Good idea but instead of cutting the middle I would cut an end and re wel the brackets back on. it would look cleaner. Quote
Technics Posted January 4, 2007 Author Report Posted January 4, 2007 Red Beretta red brace looked O.E.M. to me?? Have all the parts you need took top and bottom shroud ,light and lens switches e.t.c. Front switch for the top N.F.G but I took it also as the pigtail might be of some value. Lens for interior has pressure fracture in middle {not noticeable} light assy is much the same broken in the middle but covered by the lens{ pigtalls attached} The shrouds are mint.If your home now P.M. and I'll phone. If your a good welder you will never know it was cut and refab'd hence you weld it in the middle where it's easier to weld. {Generally welds are stronger than base material} Regards Mike Quote
Euro Posted January 4, 2007 Report Posted January 4, 2007 I dont think the STS ones will fit. they're roughly the same size as an H-body(bonne's, lesabres came factory with them). we tried fitting a bonne one onto a 1st gen at a j/y one time, too big Quote
