ihateallmustangs Posted January 1, 2007 Report Share Posted January 1, 2007 Ok so I have to hold my signal down or move it by hand to get it to flash. Its getting annoying. I replced the who mechanism in the colum from another car. Now its acting up again. Possibly from driving so long with a slightly wacked alignment. any ideas? Quote Link to comment Share on other sites More sharing options...
fastbird232 Posted January 1, 2007 Report Share Posted January 1, 2007 Get another one. Quote Link to comment Share on other sites More sharing options...
Euro Posted January 1, 2007 Report Share Posted January 1, 2007 yeah, or clean the contacts on the signal. pm discostudd(or he might post here) he has a writeup on this Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted January 1, 2007 Report Share Posted January 1, 2007 The writeup only pertains to 94+ so he won't get much use out of it. http://tss.likeabigdog.com The 88-93 switch is cake to fix, provided you have a steering wheel puller. You basically remove the top half of the signal switch, bend down the terminals, grease the contacts with dielectric grease and reassemble... Quote Link to comment Share on other sites More sharing options...
White93z34 Posted January 1, 2007 Report Share Posted January 1, 2007 i like to use paint thinner to clean the contacts before reassembly myself Quote Link to comment Share on other sites More sharing options...
1990lumina Posted January 2, 2007 Report Share Posted January 2, 2007 I bought a new switch from GM when I had to replace mine...one of the contacts fell out of the switch when I took the wheel off haha Quote Link to comment Share on other sites More sharing options...
ihateallmustangs Posted January 7, 2007 Author Report Share Posted January 7, 2007 Thanks for all the info guys. I bent the chopper clips down as said. Shes golden! Quote Link to comment Share on other sites More sharing options...
joey b Posted January 7, 2007 Report Share Posted January 7, 2007 is removing the steering wheel rather elementary? I have the same problem and will need to fix my TSS soon. Once you get the wheel off is it simple after that as well? Quote Link to comment Share on other sites More sharing options...
ihateallmustangs Posted January 8, 2007 Author Report Share Posted January 8, 2007 is removing the steering wheel rather elementary? I have the same problem and will need to fix my TSS soon. Once you get the wheel off is it simple after that as well? Very simple. I have a steering wheel puller so that was easy. After that its just a matter of uscrewing a few hex screws that hold the assembly in place. One you get the wheel off its plain as day what you need to do. Also you need to punch that pivot thingy out so you can seperate the two plastic peice (when you get it out its clear as day what im talking about) Quote Link to comment Share on other sites More sharing options...
GP1138 Posted January 8, 2007 Report Share Posted January 8, 2007 I've never removed a wheel with a puller. I use my arms, never hurt myself. It was on my old car, though, I've never taken the wheel off of my '95. Quote Link to comment Share on other sites More sharing options...
ihateallmustangs Posted January 8, 2007 Author Report Share Posted January 8, 2007 I've never removed a wheel with a puller. I use my arms, never hurt myself. It was on my old car, though, I've never taken the wheel off of my '95. I know a guy who did that on a old malibu , he took the nut off and pulled real hard till he was red in the face and smacked himself right in the face when the wheel came off. Nose was pouring blood ,etc. Its pretty tough to get the wheels of these cars without a puller I find. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted January 8, 2007 Report Share Posted January 8, 2007 I used a puller on mine..thing would not budge without one....hell I bent the metal rod that the threee bolts go into on my cheap puller I bought lol Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted January 8, 2007 Report Share Posted January 8, 2007 I used a puller on mine..thing would not budge without one....hell I bent the metal rod that the threee bolts go into on my cheap puller I bought lol I always end up bending the bolts on my puller, and I've always used Grade 8 bolts! Plain and simple, if you can pull the wheel off without a puller, then you (or whoever had your car before you) didn't torque the retaining nut down enough... Quote Link to comment Share on other sites More sharing options...
joey b Posted January 10, 2007 Report Share Posted January 10, 2007 what is the torque spec? BTW, cake job. I just did it tonight. BTW, don't lose the ball bearing that the signal pivots on. Quote Link to comment Share on other sites More sharing options...
