coolant light is still on!!!!!
I put in new cooling fan relays and my fan works perfectly, it turns on when its supposed to, but my coolant light (overheating) is still on. I took out the cluster the solder is good and is not burnt.My temp gauge i believe reads the temp perfectly. What should I do now?
replace the gauge or idiot light sending unit, the "temprature sending unit" not the "coolant temp sensor" just disconnecting the wire from the sender should make the light go out
