Help removing door panel
How do I go about removing the door panel on a 1.5 gen Lumina? I know the general idea, remove all the screws and then pop it out of place. However, where are the screws and how many will I be removing? This is on the passenger door, and I have power locks and windows.
I wasn't sure when i did my GP doors.....just get a panel clip puller thing....that helps....then just search for screws and I had a few torx bits too.
Okay, got all screws out. I can't get the top clips near the window to let go of my damn door panel. Any suggestions?
There are no clips near the window. The entire top of the panel hooks into the window channel, so you'll need to lift straight up on the panel to unhook it...
x2
not familiar with the lumis, but the GPs have a bolt nicely hidden in the bottom of the arm rest. Q-ball and I sat in the wreckers for half an hour cursing a door panel cause it wouldn't come off, then we found that bolt.
Jamie
Is there a screw in the arm rest? I read that there is in a 95+ Monte Carlo door panel removal guide but I don't see one and don't know how to remove the arm rest?
W00t! Door panel came off! I feel like a n00b, but hey, I did it without breaking anything. Now to move on to bigger things... :mrgreen:
