89oldscutlass Posted June 3, 2003 Report Posted June 3, 2003 A couple of months ago i put a cold air inductin tube and filter on my 2.8 after i put it on I noticed that i lost some throttle responce.Is this normal? Quote
Panopticon Posted June 3, 2003 Report Posted June 3, 2003 no. Does your intake have an air temp sensor? Im not sure about your particular engine, but won't the ecm retard timing if the sensor is busted or broken? Thats what i heard anyway, don't quote me on it 8) Quote
89oldscutlass Posted June 3, 2003 Author Report Posted June 3, 2003 yes i put that sensor in the tube i drilled a hole in the side of the tube and installed the sensor so it would look like a factory install. Quote
89oldscutlass Posted June 3, 2003 Author Report Posted June 3, 2003 If that sensor was bad wouldnt it show up on the computer.I had my brothers garage put it on the computer to check for bad sensors. Quote
JS91Z34 Posted June 3, 2003 Report Posted June 3, 2003 If that sensor was bad wouldnt it show up on the computer.I had my brothers garage put it on the computer to check for bad sensors. yes it will! Quote
Brian P Posted June 4, 2003 Report Posted June 4, 2003 A couple of months ago i put a cold air inductin tube and filter on my 2.8 after i put it on I noticed that i lost some throttle responce.Is this normal? Yes, put the stock airbox back in, unless you have the MAF setup- try getting a '89+ airbox and getting the updated memcal to disable the MAF. Try it and see Quote
Robby1870 Posted June 5, 2003 Report Posted June 5, 2003 Prolly lost some low end torque, and gained some high end HP, thats prolly why you felt the less throttle response Robby Quote
