evildaveprime Posted December 20, 2006 Report Posted December 20, 2006 Hi, y'all. I have a 1994 Lumina Z34. She's served me well over the years, but she's getting a little long in the tooth. Let me tell you about my problem, and maybe some of you fine folks can help. Last week, I was out working on a job site, and I had to run out to get some supplies. So off to the store I went. While on the way, I noticed that my headlights, fog lights, and dash lights were completely dead. Wonderful. Checked all the fuses in both fuse boxes, and everything looks good. Called the parts store to price a headlight switch, and they told me it would be about $165, and they'd have to order it. No way, dude. I went to the junkyard and got not 1 but 2 headlight switches. It's the kind that's on the dash between the steering column and the HVAC vent. When I swapped the old one out, it didn't work. So I did the other one. No dice. The dome light dimmer switch works fine on both, and the amber light on the headlight button is on. Then I bought a repair manual (Haynes - yeah, I'm cheap) and found the wiring diagram. According to the diagram, there should be a headlight relay somewhere in the dash, but I've had no luck locating it. Can anyone tell me where it's located so I don't have to shell out $500 to someone to take 5 minutes to install a $20 part? Quote
Redwingvksm Posted December 20, 2006 Report Posted December 20, 2006 Here, from Mitchell [attachment deleted by admin] Removed to free up storage space. Quote
Redwingvksm Posted December 20, 2006 Report Posted December 20, 2006 I don't see a relay in the wiring diagram - wtf? Did someone slip up @ GM or something? Here's what I'm lookin' at. [attachment deleted by admin] Removed to free up storage space. Quote
mhp Posted December 26, 2006 Report Posted December 26, 2006 Hy! I nearly had the same problem with my 1990 Cutlass. My Headlights were dead - only the parkinglights worked. Thought it was the Headlightswitch- bought one for €150,- - I swapped the old one - nothÃÂng happend. I wanted to yunk the car - Then I looked at the wires - I found the problem. It was the wireconnection that´s underneath the steeringwheel on the right side ( it had a bad conntact) - fixed it. now the lights work again. Quote
paulo57509 Posted December 26, 2006 Report Posted December 26, 2006 I could be wrong, but I don't think GM has ever run the headlights through a relay. The old dash mounted switches used to get pretty hot. Quote
1990lumina Posted December 27, 2006 Report Posted December 27, 2006 I could be wrong, but I don't think GM has ever run the headlights through a relay. The old dash mounted switches used to get pretty hot. x2 this is what I thought too... Quote
19Cutlass94 Posted December 27, 2006 Report Posted December 27, 2006 yeah those switches get pretty warm. But looking at the NAPA website, there is a headlight relay for the car..... You can try looking at the fuse boxes under the hood, or maybe under the dash. Not really sure where GM puts things Quote
GutlessSupreme Posted December 27, 2006 Report Posted December 27, 2006 There is a light relay/fuse center underneath the passenger side fuse box under the hood. Not sure if that's what you're looking for. Quote
DeathScythe Posted December 27, 2006 Report Posted December 27, 2006 It might be truth but I don't trust the Haynes manuals since they screwed me over on something I was figure out for my 93 Lumina. Quote
