GTPWarrior88 Posted December 15, 2006 Report Posted December 15, 2006 Hey guys...If my friend and I are going to replace the o ring on the oil pump drive, what else should we replace while we are down there? We have replaced the intake gaskets and valve cover gaskets. And how far is it from the intake gaskets to the head gasket..like what is in between? Thanks! Quote
Euro Posted December 15, 2006 Report Posted December 15, 2006 yeah, car/engine? anything else wrong with it besides the oil pump seal? Quote
GTPWarrior88 Posted December 16, 2006 Author Report Posted December 16, 2006 I have a 1995 Pontaic Grand Prix GTP...nothing else is wrong that I know of besides the oil pump drive oring. I have the 3.4 DOHC. Quote
stiv2k Posted December 16, 2006 Report Posted December 16, 2006 for that engine you will have to remove the heads to get to the O-ring...good luck! Quote
19Cutlass94 Posted December 17, 2006 Report Posted December 17, 2006 Ummm the 3.4DOHC doesnt have valve covers..... Basically, remove the plenum, remove the timing belt, take out the cams and the cam carrier, then take off the head to get to it. Once youve got there, goto GM and get this o-ring ( its like a buck ) and my friend put a shitload of RTV silicone on there to help it not leak again because of this... something else to consider doing when your putting it back together. Quote
White93z34 Posted December 17, 2006 Report Posted December 17, 2006 there are FAR less expensive ways to go about this, i have personally posted a few myself, countless times. do some searching, if that fails to yeild any results IM me, or say something here and i can go over it again. Quote
