joey b Posted December 13, 2006 Report Posted December 13, 2006 Looking to get a mate on Ebay. How do I know what numbers to match up? I have "P/N", "DOC/MBC", and "MODEL/FCC ID" I only have 1 for my car and would to get another that will work as well. Quote
turby Posted December 13, 2006 Report Posted December 13, 2006 I am sure any of the rectangle first gen style will work. Yep. Doesn't even have to be from a GM. As long as it's the same style and the lock/unlock are on top and trunk is below it will work. Quote
joey b Posted December 13, 2006 Author Report Posted December 13, 2006 I want to have a remote for my spare set of keys. That is why the exact frequency is important. Quote
turby Posted December 13, 2006 Report Posted December 13, 2006 I want to have a remote for my spare set of keys. That is why the exact frequency is important. Read much? I told you what you needed. Besides, why would there be fobs with the same exact frequency? You want someone else to have a fob for your car? That's why you have to program them for your car. Quote
joey b Posted December 15, 2006 Author Report Posted December 15, 2006 the FOB does not reprogram. The RKE module inside of the car is what programs. When my sister borrowed my car this summer I had to program my RKE to her remote. At that point, my remote no longer worked, but her remote worked for both her car and mine. When I took my car back I had to reprogram the RKE again and her remote no longer worked. It is not the FOB that programs. Does anybody know which of the 3 identifying numbers I need to match to get a remote that will work Quote
turby Posted December 15, 2006 Report Posted December 15, 2006 Blah Blah Blah It doesn't matter which part programs, the fact is you've been told 3x now you don't have to match any numbers to get one that works. See this fob? As long as the buttons are layed out like that it WILL work. http://cgi.ebay.com/ebaymotors/FIREBIRD-TRANS-AM-GRAND-PRIX-1994-1995-KEYLESS-REMOTE_W0QQitemZ160061296331QQihZ006QQcategoryZ33723QQrdZ1QQcmdZViewItem Quote
Schudini Posted December 15, 2006 Report Posted December 15, 2006 It doesn't matter. All you have to do is get a rectangular remote, open your trunk, look for the black wire next to the antenna, use a jumper wire to ground this out, let the locks cycle, push any button on the remote, remove jumper wire, put trunk liner back, close trunk, return to house and have a beer. Nice write-up. Any ideas how to get the "RKE" module to accept programming for two remotes (so joey can have his car recognize the original and the spare remotes)? I'm having a similar problem with mine. Quote
turby Posted December 15, 2006 Report Posted December 15, 2006 Nice write-up. Any ideas how to get the "RKE" module to accept programming for two remotes (so joey can have his car recognize the original and the spare remotes)? I'm having a similar problem with mine. Program both remotes the same way. Ground the wire. Push a button on 1st remote. Push a button on 2nd remote. Unground wire. BTW, each RKE will accept 2 remotes and each remote will work on two different RKE's. Quote
Schudini Posted December 15, 2006 Report Posted December 15, 2006 Nice write-up. Any ideas how to get the "RKE" module to accept programming for two remotes (so joey can have his car recognize the original and the spare remotes)? I'm having a similar problem with mine. Program both remotes the same way. Ground the wire. Push a button on 1st remote. Push a button on 2nd remote. Unground wire. BTW, each RKE will accept 2 remotes and each remote will work on two different RKE's. Sweet. Thanks! Quote
turby Posted December 15, 2006 Report Posted December 15, 2006 Don't forget to wait for the locks to cycle after each button is pressed. Quote
joey b Posted December 16, 2006 Author Report Posted December 16, 2006 thanks for explaining HOW to program 2 remotes. Problem solved. Quote
turby Posted December 16, 2006 Report Posted December 16, 2006 thanks for explaining HOW to program 2 remotes. Problem solved. So it was a misunderstanding the whole time. Quote
