removing rear bucket seats
Under the seat cushions in the center close to the front edge. Pull up on the front edge of the seat cushion and you should see the bolt. I think they're 13mm, but could be a weird size like 12mm.
Once you get the bottom cushion out, there's just a couple of nuts holding the seatback on. You take those out, then lift up and the back will come out.
