Found a wire...
Addicted To Boost
I was working on the TGP today and found a disconnected wire. It is the red wire pictured below coming from the box next to it. Where does this plug in?
The other plug next to it is for the washer pump. Any ideas to what this wire/plug connects to?
Thanks
Somehow I knew before opening this what it was about..
I was thinking "fuel pump test wire or underhood light" when I clicked on this thread. :lol:
This should be in the FAQ's if it isn't already.
its the turbo prespooler, load that puppy onto a switch 12v AC gonkulator window, hit it before racing, spools the turbo to 22psi before ya launch...
or it turns on the fuel pump, either one
its the tail light fluid sump motor wire. when your car is equipped with a 5 speed you can dump the clutch and the framice lights up, the piston return springs will turn over the tires pretty damn good. should see 13's
NO! NO! NO!
YOU FOOLS!!! The car is an older model... It doesn't use blinker fluid.... That is the recharge wire for the old fashion flux capacitor that has to be recharged yearly to manually toggle the blinker lights on and off!
^^^ hes just saying that because he wishes he could hit 13s
you wish you could go faster than an auto
