Mach 5 Posted December 10, 2006 Report Posted December 10, 2006 1989 Gran Prix My steering wheel controls stopped working. The horn still works. Where should I start checking to get them back up and running? Thanks Quote
Regal_GS_1989 Posted December 10, 2006 Report Posted December 10, 2006 could be the contact ring behind the steering wheel thats worn out. If you can pull the wheel, thats the first thing i would check Quote
97CuttySupSL Posted December 14, 2006 Report Posted December 14, 2006 1989 Gran Prix My steering wheel controls stopped working. The horn still works. Where should I start checking to get them back up and running? Thanks did you put a aftermarket hu in? Quote
Mach 5 Posted December 17, 2006 Author Report Posted December 17, 2006 It s all stock. It has always worked fine until a couple days ago. It hasn't worked since. This is how it al happened: I got it my car and started her up. Turned on the radio and then turned the volume up using the steering wheel controls. Then, I went to go turn it down after a few minutes as my mother was getting into the car. Then it went crazy. The volume shot all the way up and the buttons didn't work. So what are my options? Quote
Mach 5 Posted December 20, 2006 Author Report Posted December 20, 2006 Thanks for the help. I believe the contact ring or something like that must have moved or something as it now works. All I did was pat all the controls a couple times and it started working. Quote
